Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 to '49 Olds?
  #93 (permalink)
Old 01-07-2009, 11:14 AM
rhalko1969 rhalko1969 is offline
39 olds frame
Hi Guy's,
I have never done this before so your help is WELCOME and THANK YOU!
Before I start any thing I'm going to compare the 58 Pont lower arm measurements I got from earier in the post and compare them to the 39's lower arms. Then If that is a go I will take the Coil Spring out of all 4 corners and level it front to back and side to side at the ride height I'm looking for.
So far I have decided to go with '58 Pont Arms, '63 Pont Spindles, Scarebird Adaptor plate and '77 Pont Rotor and Calipers. This will be cheaper than the $699 CPP wants for there Complete Drop Spindle Brake kit for '67-70 Chevy.
I attached a couple photos that I would like both of you to look at just for clarification. Am I understanding both of these right?
Thank You,
ID:	35453   Click image for larger version
