Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 to '49 Olds?
  #100 (permalink)
Old 01-09-2009, 11:21 AM
oldguy829's Avatar
oldguy829 oldguy829 is offline
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
s10 to 49 olds
If you have room, go for the 9 inch.
Check out the wiki on the cavalier rack install. One issue is the length of the steering arms. To get them in sync with the rack travel I used Chevelle front steer arms and flipped sides to make them rear steer (slight grinding to fit the spindle but I may have had to ream them to fit). If you use the stock chevy arms they are too long and will reduce your turning radius.
