s10 4speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2011, 02:26 AM
s10 4speed
hi i was just lookn for sum info to help me put a 4speed in my truck.i got a hyd 4speed out of a 1988 s10 it had a remove able bellhousing what bellhousing do i use so i cn get my truck going again?
Old 01-05-2011, 09:40 AM
big gear head's Avatar
High Performance Rear Ends
If this transmission came from a 2.8 or 4 cylinder S10 then it won't work behind a V8 without some modifications. The input shaft and bearing retainer are too long. These transmissions are weak.
Old 01-05-2011, 03:51 PM
s10 4spd
the trans came off a 4.3 s10.but the bolts that bolt holes on the trans r diff then the ones on the bellhousing
Old 01-05-2011, 04:40 PM
Some of the later GM T5 transmissions had the same case as the Mustang, so you might have one with the Ford bolt pattern.
Old 01-05-2011, 04:46 PM
s10 4spd
this one came from an astro van it the same one thats in the s10
Old 01-05-2011, 04:49 PM
If it's a T4 then you can probably make a T5 out of it. Do you know if it's a Borg Warner transmission?
Old 01-05-2011, 05:36 PM
runn141's Avatar
the 5 speeds from the 2.2's in the 94 models and up were.
Old 01-05-2011, 06:00 PM
s10 4spd
yes it a Borg Warner transmission.how can i make it a t5 when there is only 4 gears?
Old 01-05-2011, 06:30 PM
I have converted many of the T4 transmissions to T5 by adding the 5th gear. The transmission that is in my truck right now is a 4 speed that I converted to 5 speed. 5th gear is inside the tail houisng, and as long as the counter gear has the snout for the 5th gear then you can add it. You will need parts from a scrap T5 to make the conversion. You will need the 2 gears and the shift linkage that is in the side of the case. You will also need the shifter gate that mounts below the shifter. This will only work in a T4 that has teh snout on the counter gear and a bulge in the side of the tail houisng.
Old 01-05-2011, 06:52 PM
4spd
ok what about the bellhousing? that the plroblem im haven the bolt holes where u bolt the trans to bellhousing wont line up
Old 01-05-2011, 07:15 PM
You didn't say what engine you are trying to mate this to. If you are putting it on a Chevy V8 then use the 4.3 bellhousing that the transmission was on. If you need mechanical clutch linkage then you will probably have to redrill a stock bellhousing or get a Mc Leod bellhousing that is made to adapt a Ford transmission to a Chevy engine. Or you coudl transfer all of the internal parts into another case that is drilled for the Chevy bolt pattern.
Old 01-05-2011, 07:45 PM
4spd
its goin on a 350 chevy an it came off a 4.3 but the trans came out of an 87 s10 im changen the bellhousing but the the bolt holes dont line up
Old 01-05-2011, 08:55 PM
What bellhousing are you going to use?
You know that this transmission will break if you abuse it with the 350, so you need to be easy on it. They are pretty weak transmissions.
Old 01-05-2011, 09:09 PM
4spd
the one off the 4.3 out the astro van but tne trans is out if an s10
Old 01-06-2011, 09:08 PM
4spd trans
thanks for the help i got it mounted to the trans. i just drilled new holes an tap them out. again thanks for all ur help
4speed auto what to get tomthecomic Transmission - Rearend 1 11-10-2007 09:14 AM
4speed shifter hotrod66_57 Transmission - Rearend 14 08-09-2004 09:30 PM
Muncie 4speed bowtieorbust Transmission - Rearend 3 07-24-2003 09:47 AM
heh-bt 4speed toploader servant70131 Transmission - Rearend 1 03-26-2003 08:40 AM
4speed Chev trannys? '66Biscayne Transmission - Rearend 2 03-08-2002 04:59 AM
