s10 4x4 v8 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2002, 10:03 AM
Post s10 4x4 v8 conversion
i was wondering if any one could give some help on swapping out my 4.3L with a 350? i am only 18 so i don't know much. What all do i need to do it. i know i need a radiator, dual electric fans, motor mounts, and headers. my 4.3 that i have in it now is fuel injection, could i put a carb. 350 in it? the trans. is a 700r4, would the 350 bolt up to it? also my truck is a 4x4 so would it be harder to put a v8 in that a 2WD? i know that its a lot of questions but if any one could help me out it would be greatly appreciated.
Andrew
Old 10-13-2002, 11:08 AM
viking37's Avatar
Post
Here are a couple of pages with good info..
Or Here
[ October 13, 2002: Message edited by: viking37 ]</p>
Old 10-13-2002, 12:02 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
I'm not sure about the 4wd but they make conversion kits to adapt 350's right in. You won't have to use electric fans but will need to get a larger radiator for the added cooling.
Kevin
Old 10-13-2002, 12:41 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post
The most reliable radiator that I could think of for an S10 would be a BE COOL radiator made for a V8 S10...If you would like to have one built or bought out of another car...A Factory V8 Monza radiator will work. That's what I had in my S10.
<a href="http://www.jagsthatrun.com/" target="_blank">http://www.jagsthatrun.com/</a> This guy specializes in thet sort of thing that you are wanting to do.
Also Jeg's or Summit carries the neccesary parts also. Give them a call or a click.
Later,
WEIMER
Old 10-14-2002, 01:13 PM
80Camino's Avatar
Post
I put a 383 stroker in an 84 2wd s-10 the headers were a major pain in the posterior.The drivers side header was three peices (or 2) been a while.Any way the leaked horrable.If i remember right there is a stock exhaust manifold that works i just cant remember what its off of though.
Old 10-14-2002, 02:26 PM
Weimer's Avatar
Post
Monte Carlo or early 80's Camaro manifolds will work...AS LONG AS the exhaust dump is in the rear.
Later,
WEIMER
Old 10-14-2002, 07:55 PM
C10's Avatar
C10 C10 is offline
All throttle.. No bottle
Post
Make sure the conversion parts you get are for a 4X4. There are some that will work on a 2 wheel drive but not a 4X4 and vise versa. Most people use Corvette radiators, they seem to fit pretty well....Advance Auto Parts has them for around $150. Also for a 4X4 you will need a special oil pan unlike a 2 wheel drive where you can use the stock pan. You will need electric fans unless you cut into the radiator support and move the radiator forward....its easier to just use the electric fans. Do your research first...its a little more expensive for a 4X4.
Good Luck,
C10
