S10 5 speed clutch disc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2010, 05:03 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
will my 11"clutch disc off my 3 speed 250 six work on the S10 5 speed. My throwout bearing fits, but dont know about the disc. I am waiting for my trans to come, and would like to know ahead of time.
Old 11-05-2010, 05:17 PM
big gear head's Avatar
High Performance Rear Ends
No, it won't fit. There is a 11 inch disc that was used in the Astro van that will work. The standard S10 disc is 9 or 9 1/2 inches.
Old 11-05-2010, 05:28 PM
Last journal entry: Paint
You need to find out how many splines on the input shaft. It should be either a 10 spline or a 26 spline. Once you know how many splines you can get the right clutch disc.
Old 11-05-2010, 05:52 PM
What engine are you using?
Old 11-05-2010, 06:40 PM
prostreet6t9's Avatar
Differential/Driveline
90-93 11 inch clutch Luk#04-089
94-95 11 inch clutch Luk#04-168
96-01 11 inch clutch Luk#04-167
02-04 11 inch clutch Luk#04-206
All listed are for S10 4.3L 6cyl. The only problem is each on of those has a different part#. All have 1 1/8 10 spline disc. Hard to tell what the difference is until I break down all the parts numbers in the kit.
Need more info on your stuff. Is your S10 a 4.3 6cyl?
Old 11-05-2010, 06:46 PM
You have to know the engine being used also. The 1 piece seal V6 and V8 engines use a flywheel that is weighted. According to the interchange book, the V6 one piece seal flywheel can also be used on the V8 1 piece seal engines. They make 2 different size flywheels.
Old 11-06-2010, 10:05 AM
Most S-10 T5 transmissions use an oddball 1"-14 spline input shaft. Only the transmissions behind the 4.3 liter V6 used the larger 26 spline input shaft. The stock S-10 clutch for this trans is a 9 1/8" clutch. There is a Jeep 9 5/8" disk with the correct 1"-14 splines, or the previously mentioned Astro van 11" disk with the 1"-14 splines.
Old 11-06-2010, 10:55 AM
http://catalog.schaeffler-aftermarke...4.3L&qualfier=
Old 11-06-2010, 11:10 AM
This is a 26 spline 11 inch LUK clutch disc. It will fit 26 spline Muncie, ST10, some T5s and a few others. If you have the option, use the big flywheel. The smaller flywheels have more starter problems.
Old 11-09-2010, 12:09 AM
Camaro clutch
Has anyone tried the 11" Astro clutch on a v6 Camaro T5? I have a 1970 LT1 block, stock Camaro 10.4 flywheel (only because my aluminum flywheel was a swap meet item made by Weber that i cannot find an insert for), and Center force dual friction pressure plate. Currently I am using a stock 1"-14 spline 9" OD disc. I tried it because I had it all laying around. For everyone's info I actually had no clutch slip until I went to aftermarket heads. Pretending I can keep my close ratio V6 trans behind my V8, any help is much appreciated...and yes I am stubborn enough to actually have to grenade this trans before I swap it! Also looking to hear from anyone who has tried the LS1 pressure plate on a 2pc rear seal Gen1 flywheel.
choosing a pontiac rearend gear? AndersonRacing44 Transmission - Rearend 20 08-08-2010 02:46 PM
s10 clutch darkfleetside Transmission - Rearend 2 04-28-2009 09:46 PM
s10 engine swap... 5 speed question w_rios Transmission - Rearend 5 01-06-2007 04:38 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
65 elky clutch disc Niapym Transmission - Rearend 3 12-02-2004 06:34 PM
