S10 5-speed for GM 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2008, 09:15 PM
I'm looking for options to put a 5-speed manual behind my chevy 350 in a 32 Ford. I'd rather not spend the $1800-3000 for a new one.
Will a mid-90's S10 tranny bolt on to the crate motor? Also, how can I get a drive-shaft and rear gears to reach it to the Ford 9"? I'll also have to rig a clutch linkage.
Tips?
Old 04-23-2008, 09:19 PM
Wiki Edits: 31
Should.. it's just a T5 5spd
Old 04-24-2008, 07:12 PM
scapegoat's Avatar
You will break it! Just as I did in my s10. I had a stout 355 in my s10 with the stock 5 speed with a good clutch. The 5 speed was originally behind a 4.3 liter v6. It lasted for awhile until one good shift to 2nd gear and then...BANG! There were so many broken parts inside and the case cracked as well.
Old 04-24-2008, 07:32 PM
kc0kfg's Avatar
kc0kfg
5 speed for 350
Drive it right and you will be ok I ran an early B/W T5 from a chevy monza behind a 350 for years,
And that was in a 4200 pound 3/4 ton 62 chevy truck that we used for hauling wood to heat our home and scrap iron I put thousands of miles on that trany.
Anything can be broken th reason that trany went in there was the stock 4 speed left parts all over the place.
Brian kc0kfg
I picked up a 400 SBC and a M21 4 speed Mustangsaly Engine 22 03-05-2010 10:32 AM
s10 350 th700r4 47chevrolet Transmission - Rearend 4 06-19-2007 09:00 PM
305 head on 350 savman1 Engine 4 10-15-2006 10:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-18-2006 12:03 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
