S10 5speed to a v8 chevy bellhousing ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2008, 05:35 AM
I'm looking for cad files, or blueprint specs for the engine/bellhousing bolt pattern.
I'm trying to figure out the best way to adapt an S10 5speed for my chevyll. Don't know if I should build the adapter at the transmission or if I should space the bellhousing back from the engine to accomodate the longer input shaft on this tranny. Thoughts??
Old 05-07-2008, 07:11 AM
judd55's Avatar
I believe you can turn the input shaft down................just another option.
Old 05-07-2008, 05:20 PM
Thanks for the input, I'm open to any options!
Fred
Old 05-07-2008, 05:42 PM
I do not believe a S-10 transmission will stand up to a V8 Chevy ... even a mild one.
Just my opinion
Old 05-07-2008, 08:58 PM
Wiki Edits: 31
a S10 5spd is a T5 but with weaker internals than a V8 T5.. A World Class T5 from a Mustang would be a better option, and you could fit it to the Chevy V8 with the correct input shaft and a bell housing adaptor for the Chevy II bellhousing.
Old 05-07-2008, 10:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Believe it..Don't even bother with an S-10 5 speed..Get one from Tremec or one from a Gm that came with a five speed and the 350..There are some other trans out there as well that have a chance of holding up to a decent 350..Richmond Gear builds a good five speed that has the proper bolt pattern and input shaft..that would be a lot cheaper and better at the end of the day than cobbling something together..
Sam
Old 06-26-2008, 02:46 PM
S10 Trannie Questions
Guys, thanks for the responses. It sounds like good advice which is always welcomed. I kind of suspected that it was a weakling, but don't have first-hand experience with one so it looks like you all have saved me a lot of trouble (and probably from being stranded somewhere). All along, I thought it is probably too weak, but I'll take it easy and not do any hole-shots - we all know how long that thought would last
Thanks again
Fred
Old 06-27-2008, 05:45 AM
What about a nv3500 from a 1/2 ton?
Shane
Old 06-27-2008, 09:27 AM
Truck tranny
I wondered about that. Is this similar in size, do you know of any particular difficulties with using this in a Chevyll?
55 chevy body swapped to an S10 frame. 55shoebox Body - Exterior 26 04-15-2010 09:41 AM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 12:12 PM
Chevy S10 W/302 chevelless454 Engine 0 06-13-2006 06:56 PM
Chevy Bellhousing pattern Augusto Transmission - Rearend 6 05-12-2006 07:17 AM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 05:24 PM
