S10 700R4 to 76 Blazer swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2006, 04:08 PM
Drewnashty's Avatar
sitis nam accelero
Will my 700R4 from my '92 S10 bolt up in replace to my '76 Blazer with a TH350? And viceversa. I've read that the TH350 with the 9" tailshaft is nearly the same length as the 700r4 and I could use the same driveshaft. Is everything else going to bolt up correctly? I already figured that I may have to relocate the tranny mount.
Old 06-09-2006, 09:42 PM
airworld2's Avatar
s-10
unless you have a v8 in your s10 , the answer is no 2.8 and older 4.3 are not the same bell housing
Old 06-12-2006, 06:11 PM
Drewnashty's Avatar
sitis nam accelero
It's the 4.3L, is it worth it to swap on different bell-housing? Or is that a non-interchangeable part.
Old 06-12-2006, 06:16 PM
tnsmith10's Avatar
when will it rain???
the 4.3 bellhousing is the same as the 350 (5.7) the 2.8 has the different bellhousing.
odds r though that ull want to have it built to handle the power from the 350...
Old 06-12-2006, 07:05 PM
Crosley's Avatar
Wiki Edits: 1659
the mentioned 76 Blazer is a 2WD vehicle?
Old 06-12-2006, 09:26 PM
Drewnashty's Avatar
sitis nam accelero
Yes, I plan on doing a thorough rebuild, and parts upgrade.
Yes it is.
Old 06-12-2006, 09:30 PM
Drewnashty's Avatar
sitis nam accelero
And will the TH350 in the C10 match up in for the 4.3L in the S10? It's just a work truck with econo gears and I really have no need for 80mph low RPM cruising.
Engine swap for Blazer S10 ducktruck87 Engine 31 07-01-2010 08:44 PM
engine swap in a s10 blazer bill bennett Introduce Yourself 4 05-12-2006 10:47 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
