s10 brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2009, 10:54 PM
s10 brake booster
hey everyone, i just put a new motor in my 87 s10, and the new valve covers are hitting on the brake booster. rather than switching valve covers i'm going to switch my brake booster, i know there are ones that have a smaller radius but are thicker, anyone know from what kinda vechicle i can get a brake booster that will fit this truck, but has a smaller diameter? if pictures are needed i can get them. i'm just a rookie so i'm not sure if any brake booster will fit this or if my setup will effect which one i need, any help would be appreciated, thanks.
Old 03-15-2009, 04:24 AM
i think a geo metro will work but not for sure what size engine did you install.
Old 03-15-2009, 07:35 AM
its a 350, i got a set of edelbrock valve covers, where can i get a geo metro?
Old 03-15-2009, 07:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by haulinass-10
...where can i get a geo metro?
Better question is where can I get rid of a Geo Metro!
Old 03-15-2009, 07:42 AM
oh **** lol, my bad lol yah sorry i just woke up, not the nicest cars are they lol
Old 03-16-2009, 12:46 AM
u can check local salvage yards or advance auto part #53-2360 what kind of motor mounts u using because u should be able to slide the engine forward a little.
Old 03-16-2009, 05:57 AM
yeah that s what im wondering what size motor and how come your covers are hitting wow what about the wiper motor and headers u must be right up against your steering shaft to be that close to your booster. id be switch the valve covers instead.. and checking the motor mounts somtin aint right there bud
Old 03-17-2009, 06:53 AM
runn141's Avatar
what diameter is your booster? i have seen small and large boosters come factory on these trucks. some are about 10 inch diameter and the other is about 12 inch.
Old 03-19-2009, 07:28 PM
i got a pair of these valve covers these ARE like 1.5" taller then my M/T valve covers
Old 03-19-2009, 09:41 PM
they are the same mounts as i used with my last 350 and i'm not sure the diameter because i'm living in another province until april but everything else is fine its just the valve cover, the headers wrap around the steering shaft so that's not an issue, i would have to say it would be the 12'' booster, but if i go to a junk yard i can just pull the booster from any vechilce with a 305 or 350? lol this is my first truck and i'm only 18 so i'm sure my questions are stupid but yah hafta learn sumwheres!
Old 03-24-2009, 09:07 PM
you can use the universal gm "chrome/natural hotrod" brake boosters like they have on ebay the 7" and 8" ones. the studs on them line right up with factory holes. just need to cut the loop off your factory one and weld it to the bolt on the new one so your brake switch works normally. also people use geo metro brake boosters and also the hydroboost units from astrovans.
Old 03-26-2009, 03:56 PM
i put my edelbrock valve covers on they fit w/o hitting the break booster?
Old 03-26-2009, 09:26 PM
shorter valve covers clear, tall wont. unless you mount the motor real low in which case youll probably be putting a smaller pan on or notching frame.
Old 03-27-2009, 06:57 PM
so how complicated is it exactly to change brake boosters? and as long as i go to a junkyard i shoudl be able to get the right brake booster to fit right?
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
S10 Power Brake Booster. Want to remove S10 Racer Suspension - Brakes - Steering 3 03-09-2008 08:43 PM
Minus the brake booster?? dpjmw Suspension - Brakes - Steering 4 03-16-2005 11:20 PM
Brake Booster mac Suspension - Brakes - Steering 3 06-26-2002 06:07 PM
brake booster 34Plymouth Suspension - Brakes - Steering 3 02-14-2002 08:53 PM
