This might sound like a dumb question but does anyone know if the front disc setup from a late-80's S10 work on a 71 Chevelle? The reason that I ask is I have an 89 S10 that I am stripping parts off of and I was wondering if I could use any of the front suspension parts on my Chevelle frame.
Thanks, WEIMER |
dont know the answer, BUT I'll say it again, ITS really ODD seeing my last name in print, since its not a very common name, hell we might even be distant cousins, who know??????....joe
Well I dont know if this helps, but the S-10 brakes are the same as the late seventies and early eighties malibus.
Chris |
Well folks I went out to yank some more parts off of the S10 today...after I got the frontend off where I could see the A-arms I went and grabbed the A-arms from the Chevelle to compare...all of the mounting bolts line up perfect and the ball joints are still located in the same place. Believe it or not the S10 A-arms look a helluva lot beefier than the Chevelle arms do...Gonna give it a shot. The most that I can be out of is my time, since I already have the parts...right?
Later, WEIMER |
yep they will fit. also read that you can up-grade to 11 or 12 inch rotors by using full isze GM rear wheel drive spindles & upper control arms.....
joe weimer <~~~~ yep thats the name [ May 23, 2003: Message edited by: TooMany2count ]</p> |
I do a lot of disc convershions,74 down is all i`ve ever used. And i`m running out of supplyers.
If the s10 will work please let me know. I`ve never herd of it being tried,they do look close. |
