S10 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 12:31 AM
S10 build
hey guys I'm building a S10 with a V8 just need to ask some question,Want all needs to change just to get the motor to set in the truck, Wants the cheapest way to go on motor mount I'm going with manefolds not headers I putting a old stlye 350 crante motor in there going to try to use the oil pan thats on it hope it works any hits that ya'll can give will be thank ful what motor mounts are being used if you go with like the stock oil pan on a 84 motor what headers please guys give all you have thanks
Old 11-01-2010, 12:36 AM
Wiki Edits: 31
4.3 S10 motor mounts with swap adapters... Speedway Motors has the adapters cheap.
Old 11-01-2010, 12:48 AM
S10 build
thanks Matt,want about the wiring like the power to the coil and power to the throttle body how are they making the V6 wiring harnest work on the V8 motor and do I need to change anything in the computer
Old 11-01-2010, 05:12 AM
you'll find all the info you need for the swap on www.v8s10.org
Old 11-01-2010, 07:18 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
just did one.put a 383 in it. not bad at all.the mounts i used have some adjustment in em so you can move the engine about an inch back or forth.worked dang good.the headers fit nice too..its not a bad swop.you mite want to take a look at the radiator. it mite be a bit too small for the v-8.we used a 700r4.worked out purdy good .hope you have as good of luck as we did.
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
Outline to build a 32 54marko Introduce Yourself 1 07-09-2007 06:29 PM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 04:39 PM
First Rod Build - T Bucket , here we go Gr8lite Hotrodding Basics 10 06-29-2005 02:42 PM
v8 S10 build Surfer1130 General Rodding Tech 34 01-12-2005 06:05 PM
