s10 coil spring rear
i'm modifying an s10 frame so i can put a 40 ford body on it. i was thinking about cutting off the rear portion of the frame just behind the rear axle and converting to coil spring rear suspension. i was wondering if you could cut the leaf springs just aft of the rear axle and use the front of the leaf springs for lower trailing arms. looks like it would work fine. just wondering........
[QUOTE=fasttrain49... looks like it would work fine.......[/QUOTE]
Yeah, except for the part about the springs beind designed to flex...
I do have to say, It is much easier to make the mods to the ford frame.I would not do what your planning..But that's just the way I do things...Good luck.....
s10 suspension
first off, i don't have 40 ford frame money. second, the body is fiberglass and will fit the s10 chassis pretty nice except for the rear area. what i will probably do is bob the rear and run a 4 link and then make the rails follow the trunk floor. why go this route? lack of dough. the leaf spring idea just looked as though it mite work and save a little work.....
Understood, I wondered about a Fiberglass body after I posted as a friend did a 41 Willys glass car with an S-10 frame. The leaf idea will work fine if you don't intend to put much power to it, I would guess 300 hp or less. Clamp all of the leaves together at the tip of each one or make a tube link to bolt to the leaf pad on the housing and pivot at the original leaf eye bracket on the frame.
| 9 inch ford G body rear axle questions, advantages STD spring, coil over | eatonde | Transmission - Rearend | 9 | 01-21-2009 11:11 AM |
| Rear Coil Over Kit Geometry Problems | bbfalcon | Suspension - Brakes - Steering | 21 | 05-13-2008 04:31 PM |
| front and rear coil springs question | hddave1 | Suspension - Brakes - Steering | 2 | 04-17-2008 10:12 PM |
| Rear leaf spring modifications! | V8 Super Beetle | Transmission - Rearend | 1 | 03-24-2008 04:21 PM |
| Front Coil spring orientation on IFS | fosterdl | Suspension - Brakes - Steering | 2 | 05-16-2007 05:51 PM |
