s10 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 07:13 PM
s10 conversion
hello again. a new question. in this conversion, the donor truck was a 1982 short bed, i am installing sb 383. the gauge cluster is from a 1988 non electronic speedo with gauges. in the hayes reference book it appears that the the gauges are controlled via a resistive type sensor. with the small block using an eldebrock intake what resistive range sensor should be used to control both the temp and what type for the oil in the block. it appears in parts books they are 82 ohm. should i go with this?
Old 08-04-2010, 09:11 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Just get the appropriate senders for an 88 S10 with a 4.3 and adapt them with bushings if you have to. This is foolproof.
S10 V8 Conversion pointers........ chevy350_Camd Hotrodding Basics 18 06-12-2012 01:42 PM
83 S10 2.8L w/700R4 4WD to 94 4.3L 4L60 2WD conversion dannyr Hotrodding Basics 5 01-27-2009 11:07 PM
84' S10 conversion problems (starter) thumper040392 Hotrodding Basics 9 12-31-2008 08:39 AM
Serpentine Belt Conversion for 1984 S10 WR Mouton Engine 1 10-26-2008 06:06 PM
Header Tube Size - S10 V8 Conversion S10 Racer Engine 1 07-13-2008 11:38 AM
