We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 11-19-2002, 05:20 PM
wvs10 wvs10 is offline
Cool s10 disc brake conversion
any thoughts on using rear disc brake setup out of a camaro and put into an s10?
Old 04-09-2003, 02:11 PM
ddrake01 ddrake01 is offline
Post
Did you find out any information on this? I sick of seeing kits at $750+ to do this. There has to be a cross-over part considering it's GM with Camaro lug pattern... Email me at ddrake@usthq.com
Old 04-09-2003, 07:52 PM
bonuts's Avatar
bonuts bonuts is offline
Got Ouzo for touzo
Post
The only bad thing about a Camaro rear in a S-10 would be width, you would have to have it narrowed, or have that old style tires sticking out 2 feet kinda thing going on. Yuk, well atleast it would look gross on a S-10.
bonuts
Old 04-10-2003, 03:32 AM
tomslik tomslik is offline
3rdmember
Post
orrr, how about just using the camaro stuff on a s-10 housing?
Old 04-10-2003, 05:15 AM
farna's Avatar
farna farna is offline
farna's barnstar
Wiki editor
Last wiki edit: Identifying AMC/Rambler Gen-1 V-8s and transmissions
Wiki Edits: 11
Post
There's an easier way if you have access to a welder. Speedway (www.speedwaymotors.com) makes a universal kit for just under $500. No park brake, but everything else you need. Come to think of it, they have bolt on brackets for a lot of applications, with complete measurements in their catalog. The catalog is worth the $5 (free with a $25 or more order) for the info in it on mixed things -- the bolt pattern of axle housing ends in the brake section, spring rate calculations for coil overs in shocks, etc. I think they have a lower cost kit that has everything but the GM front calipers, and of course they have higher priced kits that include park brakes. If you run an auto trans anyway, screw the park brake! Of course I know how to park a manual in gear with no trouble either...
Now to do it with junkyard parts isn't that bad. Late 80s big Cadillac Eldorados and Sevilles have rear discs. The only thing about using those calipers is that you have to use the park brake -- that's how they adjust the brakes, through park brake action. Unlike other calipers, these have to be adjusted to work right. You can substitute front calipers as far as I know. You can use the mounts and rotors on any GM. The mounts may have to be cut and welded to your axle housing. Weld on mounts can be purchased from Speedway also. Some front drive rotors may be usable, but you'll have to check for clearance with the wheels. Most front drive rotors and the Caddy rear rotors slip on the hub just like a rear brake drum. So do the Speedway rotors (you could just buy the rotors and brackets from Speedway). Check the front rotors of 4x4 trucks. On Jeeps (the little Cherokee) the front rotor slips off like a drum. If nothing else you can drill a Jeep front rotor for a Chevy pattern. Check the offset -- the Jeep rotor might be to deep.
Just cut your original brake backing plate to cover the end of the axle only. None of this is hard, just visit a pull your own parts yard and look around!
Old 03-07-2004, 08:38 AM
69chevl 69chevl is offline
Theres a guy in the mid west that makes brackets for converting muscle cars to rear disc setups using camaro and vette parts. he sells these for around 85.00 plus shipping. I have an e-mail into him asking how to convert my 86 s10 to rear discs. When I get a response I'll post his answer. If there is a big enough demand maybe he can make these up for the s10. Does anybody know if the late 70's- early 80's 10 bolt has the same backing plate bolt pattern as the s10's?
Old 03-13-2004, 08:45 AM
rear S-10 disc brakes
The guy got back to me re: rear disc brake brackets and no go right now. He hasn't made these yet. If I hear from him I'll post an answer.
Old 03-13-2004, 05:12 PM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
In the late 90s, some Blazers/Jimmys came factory with rear disc brakes. It would be a direct bolt on conversion for S-10s (1994 and later for sure, i dont know if the pre 94 rear ends were the same). I used to have a 95 S-10, and even found a 4 door blazer at a salvage yard with this rear end. I ended up selling the truck so never performed this swap.
Old 03-13-2004, 10:24 PM
Weimer's Avatar
Weimer Weimer is offline
Kenneth Howard hates you...
I believe that it was the 4x4 that had the rear disc brake setup...if you are planning on swapping a 4x into a 2x you'll run into the same problems...the 4x axle is wider.
Later,
WEIMER
Old 03-14-2004, 09:49 AM
I was told you could just remove your entire drum assembly and replace i with the disc assembly, and it wouldnt make it any wider. But like i said, i didnt look in to it that much because i sold my truck.
Old 05-30-2004, 08:03 PM
rob king rob king is offline
rear disc conversion
I have done this conversion on a 98 sonoma. I used a 4wd rear out of a 01 s-10 blazer. Had to have a very small amount of machine work done. System works great and i one of a kind on my model and year truck. Want more info let me know.
Old 05-30-2004, 08:49 PM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
The late camaro and firebird will bolt on to the early camaro. Also the caddy will to. It should go on the S 10 also , and be sure and use the emergency brake system from the donor.
You may have to cut or grind an 1/8 inch off of the axle flange.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
