s10 doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2014, 05:14 AM
docs57's Avatar
s10 doors
Hi folks, I hope some one on here can help me , I just put new doors on my 89 S10, one lined up OK ,the other needs it bad, About a 1 inch drop , its a fixed hinge, I don't know how to adjust, help please.thanks ahead of time. Doc.
Old 07-11-2014, 06:22 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Those hinges are welded to the door and the cab correct? You mentioned "new" doors, are these doors brand new, or just new to your truck? Did you change them by removing and changing the hinge pins and bushings, or did you cut and re-weld the hinges? Answering some of these questions will help us get you on the right track to a good solution.
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
docs57 (07-12-2014)
Old 07-11-2014, 07:50 PM
Dimwit
Last journal entry: S10 fabrication (cont'd)
My 95 S10 doors have bronze bushings around the pins through the hinges. Are all of your bushings in place?
The Following User Says Thank You to Supercharged03 For This Useful Post:
docs57 (07-12-2014)
Old 07-12-2014, 05:29 AM
deadbodyman's Avatar
Wiki Edits: 11
if the bushings are good you have to bend the hinges to adjust the door. usually you can jack up the door with a floor jack and bend it that way.
The Following User Says Thank You to deadbodyman For This Useful Post:
docs57 (07-12-2014)
will s10 pickup fit S10 blazer chassis? peab007 Hotrodding Basics 4 02-28-2012 08:45 PM
Need Help on doors 10asee Body - Exterior 1 11-11-2011 12:47 PM
Should I take off the doors? trifivefan Body - Exterior 2 06-19-2008 07:07 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
Where are the doors? 26trackt Body - Exterior 0 12-03-2002 03:34 PM
