S10 driveshaft conversion to early chev rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2013, 08:29 AM
mrcaruso's Avatar
S10 driveshaft U joint questions
I'm looking for a ujoint that might fit the S10 driveshaft and a 1956 chev rearend yoke. Anyone have any ideas? I know this not the usual swap, but I was never one to make it easy!
Thanks..............................
I'm looking for a ujoint that would convert an S10 driveshaft to a 56 chev rearend yoke.
Old 07-31-2013, 11:13 AM
big gear head's Avatar
High Performance Rear Ends
Precision and other companies make conversion U joints. You need to go from a 3R u joint to a 1310 u joint.
Old 07-31-2013, 01:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mrcurso, I merged your posts. You posted your new question in an old thread. That confuses the membership on who asked what question.
You also started a new thread with the same question.
I merged both posts here for one thread
The Following User Says Thank You to Crosley For This Useful Post:
mrcaruso (07-31-2013)
Old 07-31-2013, 02:08 PM
How did this happen?
Old 07-31-2013, 03:15 PM
mrcaruso's Avatar
thanks.......I will look into that
Old 02-03-2014, 09:16 AM
67Elcamino's Avatar
How did you determine that the S10 u joint are type 3R Ive been measuring my S10 ujoints and verfying against catalogs and did come up with dimensions for a 3R. I did however come close to that of 7290.
Old 02-03-2014, 11:54 AM
mrcaruso's Avatar
I took the driveshaft to a local place in Post Falls, Idaho (Drivelines Inc). The part number he used is 3-3130, which apparently mates a stock S10 4x4 driveshaft to a stock 56 Chev pumpkin. Hope this helps out.
Old 02-03-2014, 11:56 AM
mrcaruso's Avatar
Thanks for taking care of me! I was new to the site and obviously missed the forum name.
Old 02-03-2014, 02:22 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
http://www.skf.com/binary/12-66357/457285.pdf#page=323
This shows P/N 3-3130 to be a 1310 to Saginaw S44 conversion joint
( I believe S44 is equivalent to the "3R" designation)
The "7290" spec mentioned above is slightly longer (2.622")
versus the 2.556" measurement of the S44
Old 02-03-2014, 10:06 PM
67Elcamino's Avatar
66GMC I agree the 3R does seem to be a closer match.. I re-measured all carefully and do agree the S10 ujoint is a 3R and I did see a reference stating that it is the same as an S44 or also a saginaw??
Im looking for a conversion ujoint from a 3R to a 7260 but cant seem to find. Does such even exist?
Old 02-04-2014, 09:13 AM
66GMC's Avatar
1.) I've already stated that I believe that the S44 and 3R are the same spec.
(1.125" caps with a 2.556" inside lock-up.)
2.) 3R to 7260 conversion joint does not appear in the catalog that I linked to previously. I'm not saying that it "does not exist" ... but it will likely be a tough one to find, at best, as SKF/Neapco is a pretty comprehensive product line.
It may be time to ether swap a yoke or have a custom tube welded up that uses a more common dimensional combination?
Inland Empire Custom Made Driveshafts
The Following User Says Thank You to 66GMC For This Useful Post:
67Elcamino (02-09-2014)
Old 02-09-2014, 11:32 PM
67Elcamino's Avatar
I believe there is no such combination. I going to have to have a driveshaft shop weld up a yoke mount for me.
Old 02-10-2014, 06:04 AM
Many people with the 2nd gen Camaros have made this swap. They are finding the u joint somewhere.
Early Chev/oller Cam Chev Differences belairheaven Engine 1 08-14-2010 08:31 AM
Early Chev/roller Cam Chev Differences belairheaven Engine 4 08-14-2010 05:59 AM
Chev Auto to Early Hemi Conversion jsrail Transmission - Rearend 4 05-12-2009 07:57 PM
s10 driveshaft question SSon18s Transmission - Rearend 3 12-09-2006 09:09 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
