Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 Floor Suggestion
Old 12-16-2012, 07:29 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by delawarebill View Post
are u talking about welding the alum floor to the sides somewhere???? the side portion is steel and u can't weld steel to alum... i'll assume i have your comments wrong and the above is not a valid answer..????
yes the floor will be riveted down. The trans tunnel portion will use those quick release clips for easy access. I forgot to add the rest of the pictures. Ill do that now.
Do you think If I prep the driver side mount as I said it will be okay? Its pretty rusty as is.
