Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 Floor Suggestion
Old 12-22-2012, 08:39 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by Old Fool View Post
Back in the day where I worked , they welded tons of aluminium to steel. Connections strong enough to hold the superstructure on ships.
The process used was out of reach of most.
I was working at Kaiser Aluminium as a millwright.
The company had received an order from a defence contractor for a special application.
It was very interesting, take a plate of steel, and a plate of aluminium, and roll them thru a hotmill.
The millions of tons of force generated when passing through the mill cause the steel and aluminium to fusion weld together.
I wish I knew which ships received this product and how well it worked.
It was an extremely noisy process which we called thunderplate due to the noise of the plate moving down the roll tables.
The defence contractor would cut the plate into specific size and shape then weld the steel to the ships deck and weld the new aluminium superstructure to the aluminum side.
Hmm thats pretty cool. Never heard of that before. Learn something new everyday!
