Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 Floor Suggestion
Old 12-22-2012, 08:41 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Does anyone have any input or suggestions on the floor and how I should tie the floor into the cab and the cab into the frame? I figured I would use the existing cab mounts just replace the previous nut that floated in the housing with just a welded nut and a solid spacer to make up for the absence of an actual rubber mount.
