s10 front springs v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2007, 10:53 AM
47chevrolet's Avatar
BuRnIn RuBbEr
Last journal entry: 350
Will the stock springs from the 4 cyl hold a v8 400ci
Old 04-24-2007, 09:28 PM
runn141's Avatar
SB S10
barely and they will bottom out hard. 4.3 springs will lower the front 1inch (so ive heard).
Old 04-25-2007, 04:54 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
A quick and easy check (for you): Have a buddy crawl up on top of the 4 cylinder and check out the deflection. Since it will be, at the most, half an inch, you probably will wonder why you ever worried about it.
This matter of changing springs is probably the biggest factor in causing second thoughts after an engine swap. Rodders go to higher rate suspension springs when they swap a V8 for an inline and then are unhappy with the handling. The car pushes badly in a corner. "Well," their buddies tell them, "it's because of that big heavy engine up there." No, it's not! It's because of the increased front roll stiffness from the higher rate springs. If you feel you MUST install higher rate springs, be certain to add a beefier rear anti-sway bar or you're going to be unhappy with the handling.
Old 04-25-2007, 10:50 AM
BuRnIn RuBbEr
air shocks
what if i put air shocks up there too then it would be okay u think
Old 04-25-2007, 08:30 PM
S10's came with stiffer springs then V8 G-bodies that used the same suspension.
http://jeffd.50megs.com/Moog_Spring_Page.htm
Old 04-27-2007, 09:37 AM
S10xGN's Avatar
Gotta love a turbo!
My '96 has stock front 4 cyl springs. The Buick V6 with the intercooler, turbo, and plumbing prolly weighs as much as an average smallblock V8. I have no suspension issues at all...
Russ
Installing new front coil springs gilliganspl Suspension - Brakes - Steering 21 12-29-2006 10:49 PM
longer front springs bct Suspension - Brakes - Steering 4 11-13-2006 09:42 AM
front end spring's goody Suspension - Brakes - Steering 1 03-12-2005 11:08 AM
Front coil springs too long. hrussel Suspension - Brakes - Steering 7 07-05-2004 08:23 AM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 05:24 PM
