s10 hot rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 09:35 PM
s10 hot rod
I'm trying to set the timing on a 1975 chevy 350 i've set it twice and it keeps ending up at 180% off can you help me get this set right? I put the marks together.
Old 07-04-2010, 07:22 AM
You have probably figured it out by now, but in case you haven't, the sbc timing marks on the dampner will line up with the timing tab on both #1 power stroke and #6 power stroke. Pull the #1 spark plug and crank the engine by hand until you feel pressure on your finger to let you know its on the #1 compression stroke. Slowly keep rotating the crank and as the timing mark on the dampner approaches the timing tab, it will be on the right stroke to set your timing(dist rotor pointing to #1 post). If not, remove dist. and rotate it so that when you put it back in, its pointing towards the #1 terminal on the cap.
ssmonty
My First Hot Rod!... project TexasTechX1 Hotrodding Basics 46 04-21-2009 07:40 AM
Hot Rod Art Book futureelements Hotrodders' Lounge 1 02-06-2009 05:33 PM
hot rod Fabrication Denton Md frdsuperduty Introduce Yourself 4 04-14-2008 08:11 AM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 04:11 PM
My Hot Rod, is now a SHOT ROD! bullheimer Hotrodders' Lounge 3 04-15-2004 10:25 AM
