Hi guys, I was going to use an S10 Blazer frame for a project, maybe an old truck. Than I met a guy who has an S10 pickup frame. I've heard bad things about the rear kick-up on the S10 Blazer frames. Would I be better off to see about the pickup frame? Thanks in advance. Rod
The only real difference is wheelbase. That might be the problem with the Blazer kick-up -- it's to close to the cab on some old trucks. Would make for a very short bed. I'm pretty sure (but not certain) that the S-10 Blazer fram is shorter than a short bed S-10 pikcup frame.
There is the Blazer frame, regular cab pickup, and extended cab pickup....all different wheelbases. there are also 2 and 4 wheel drive of each.
For a 50s pickup to S10 frame, I would think that the extended cab frame would be the closest. Also, it is easier to shorten a frame than to lengthen one.
The short answer is the 2 door S10 Blazer has a 100.5" wheelbase, the longbed pickup has a 117.9" wheelbase, and the longbed, extended cab pickup has a 122" wheelbase.
Check out these two links. They're from a webpage set up by Hotrodders.com member Stinkin V8. He's putting a '52 Suburban on a modified S10 frame. The first link chronicles his experiences with actually mounting the body onto the frame.
If any of you are interested, I'm putting a 52 Ford F-1 pick up on an S-10 frame. At the same time I've created an edition to my website covering this frame swap with pictures, guidelines and information. Right now it's in the beginning stages and will grow as the swap progresses.
The website is:
Note: I wasn't going to announce this until it was completed, but it looks like the S-10 frame swap has become more and more popular as time goes by.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
