-   -   S10 rear drum to disc swap (http://www.hotrodders.com/forum/s10-rear-drum-disc-swap-224312.html)
jayd_2 09-23-2012 06:02 PM
I have a 1989 S10 2WD frame under a 1937 pickup body with disc/drum brakes. I'm swapping the rearend for a 2WD Blazer with disc.
The rear currently has an adjustable proportioning valve and the master cylinder is a 1" bore Corvette type. Do I need a proportioning valve with a disc/disc setup? If so can I use the one I have?
RWENUTS 09-23-2012 06:54 PM
THis guy has a wack of info. Your answer should be in here.
Setting Ride Heightİ, Coil Oversİ, Engine and Pinion Angleİ by Dean Oshiro
Or here.
Classic Chevy, Chevrolet, GMC, Ford technical articles
65G10 09-23-2012 09:00 PM
You should be able to just use the adjustable one for the rear.
