S10 rear drum to disc swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2012, 06:02 PM
I have a 1989 S10 2WD frame under a 1937 pickup body with disc/drum brakes. I'm swapping the rearend for a 2WD Blazer with disc.
The rear currently has an adjustable proportioning valve and the master cylinder is a 1" bore Corvette type. Do I need a proportioning valve with a disc/disc setup? If so can I use the one I have?
Old 09-23-2012, 06:54 PM
RWENUTS's Avatar
THis guy has a wack of info. Your answer should be in here.
Setting Ride Heightİ, Coil Oversİ, Engine and Pinion Angleİ by Dean Oshiro
Or here.
Classic Chevy, Chevrolet, GMC, Ford technical articles
Old 09-23-2012, 09:00 PM
65G10's Avatar
You should be able to just use the adjustable one for the rear.
Drum to disc brake swap bfhduh Suspension - Brakes - Steering 4 08-20-2012 09:01 AM
GM drum to disc swap dundirtcheap Suspension - Brakes - Steering 5 07-30-2012 08:40 AM
Nova clip drum to disc swap,help please. 68RATVT Suspension - Brakes - Steering 4 04-02-2007 10:47 PM
drum to disc swap runn141 Suspension - Brakes - Steering 3 11-08-2006 09:19 PM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 05:08 PM
