s10 rear end chop - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2012, 03:37 PM
s10 rear end chop
would like some idea,s on how to cut a nine inch down for my 88 s10 and how narrow i need the frame to b for 14 inch wide slicks,, new to the narrow rearend game,,
Old 08-17-2012, 04:02 PM
i would base my measurement off of a few things 1 being wheel width and offset to determine how wide the rear end will be and also you have to first decide how you want the tire to sit, do you want tucked in and slammed completely or do yo wanna have one those where the bed of the truck is a bit taller with the tire flush to the side of the bed. also your suspension will determine a lot also will you be running coil overs with 4 link or ladder bar leaf springs etc... there is alot of variables here
Old 08-17-2012, 07:47 PM
big gear head's Avatar
High Performance Rear Ends
I just finished building a 9 inch for a customer's S10 about 2 weeks ago. The very first thing you have to do is get the wheels and tires that you are going to use and get them under the truck in the position that you want them in. Then measure between the mounting surfaces of the wheels so that you will know how wide the rear end needs to be. Then you can start on the rear end.
Narrowing a rear end requires some special tools. You must have a housing fixture to hold everything in line with the differential bearing bore. You also need very good welding skils.
The S10 has about 12 inches of room between the bed side and frame rail. To get a 14 inch wide tire under it you will have to move the frame rails in about 4 or 5 inches at least.
Old 08-17-2012, 08:30 PM
S10 Racer's Avatar
http://www.warsprints.com
I narrowed a 9" for my "89" S10 for 16" wide Hossier slicks, the frame ended up being around 24" wide, moving each side in about 8-1/2". You have to have the wheels and tires first to see how narrow you have to go. You will also have to tub the bed depending on how much backset your wheels have. Otherwise they will be sticking out past the bedside.
ID:	67502   Click image for larger version
ID:	67503   Click image for larger version
ID:	67504   Click image for larger version
ID:	67505   Click image for larger version
rear end for s10 V8 rwa1015 Transmission - Rearend 7 07-23-2012 11:00 AM
rear end identification S10 ekwoodard Transmission - Rearend 3 10-12-2010 12:26 PM
best rear end for my s10 project? P&Rracing Transmission - Rearend 13 02-22-2009 03:07 PM
S10 rear end id help Sleeve396 Transmission - Rearend 2 07-14-2008 10:29 PM
Has anyone used an S10 rear end in a rod? 48ChryslerRodder Transmission - Rearend 25 10-09-2005 08:17 PM
