Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 rear ends
Thread: S10 rear ends
  #20 (permalink)
Old 04-15-2013, 04:39 PM
64nailhead's Avatar
64nailhead 64nailhead is offline
I have been told the Blazer is narrower but not sure if it is true.
Are you using the original carrier? If so then you need to find 26 spline axles from an 88-89 or older. I did this same conversion into a 77 last summer. Use the S10 drums and have 1/4"-3/8" taken off the brake surface inner edge to clear your stock backing plates. I changed the carrier to 28 spline due to the axles were alot beefier than the 26. If you are running a posi with any type of HP, then those 26 spline axles will be short for the world.
Good luck.
OOPS, was trying to reply to the original poster :/
