S10 rear ends - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2013, 09:27 AM
Originally Posted by runn141 View Post
i took one from a 2wd blazer with rear discs 11.6" x .787" rotors.
What year do you remember? According to GM that shouldnt exist. But GM has been wrong before.
peace
Hog
  #17 (permalink)
Old 04-15-2013, 10:36 AM
runn141's Avatar
peace
Hog
2000 model, i even got a 33mm front sway bar off it also.
  #18 (permalink)
Old 04-15-2013, 12:22 PM
Cool, thanks for teh reply.
peace
Hog
  #19 (permalink)
Old 04-15-2013, 02:16 PM
runn141's Avatar
peace
Hog
one thing i couldnt figure out is the rearend i got from the 2wd blazer is the same width as any other 2wd. but is offset 1 1/2 inch over to the drivers side. i would have to relocate the perch's 3/4 inch over to fix it.
  #20 (permalink)
Old 04-15-2013, 04:39 PM
64nailhead's Avatar
I have been told the Blazer is narrower but not sure if it is true.
Are you using the original carrier? If so then you need to find 26 spline axles from an 88-89 or older. I did this same conversion into a 77 last summer. Use the S10 drums and have 1/4"-3/8" taken off the brake surface inner edge to clear your stock backing plates. I changed the carrier to 28 spline due to the axles were alot beefier than the 26. If you are running a posi with any type of HP, then those 26 spline axles will be short for the world.
Good luck.
OOPS, was trying to reply to the original poster :/
What rear ends on '37 Vetteman61 Transmission - Rearend 9 01-17-2012 05:14 PM
why are 55-56-57 rear ends used so often... 40chevy Suspension - Brakes - Steering 5 03-27-2006 10:39 PM
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 10:05 PM
rear ends vin171 Transmission - Rearend 4 09-13-2004 08:25 PM
rear ends railrodder Transmission - Rearend 2 11-28-2001 05:03 AM
