S10 rearend on AD truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 11:17 AM
TEXAS'55's Avatar
Life is Good!
I'm in the middle of my 55.1 build and the kit I'm using is the AD-engineering one. The kit calls for a 4x4 rearend from an S10 for an additional 5". Instead of that would I be able to use a wider tire and wheels with a backspace? I guess I should of put this in the rearend forum.
Old 03-30-2007, 10:49 AM
runn141's Avatar
SB S10
i checked out the website of AD-engineering and i see what your talking about, i dont think you should have any problem with a wider wheel and tire using a 2wd rearend
Old 03-30-2007, 11:00 AM
bet on black's Avatar
hotrodder 4 life
the 4x4 rear is wider, the only problem you may have is tire clearance in the inside (clearance with the bed) but that can be fixed with wheel spacers or custom wheels if you already have the rear.
i don't know if it will cause a problem, but that would seem to be where a problem could arise.
Old 03-30-2007, 11:01 AM
TEXAS'55's Avatar
Life is Good!
Thanks runn. I didn't think it would be a problem, but it never hurts to ask........
Old 03-30-2007, 11:04 AM
TEXAS'55's Avatar
Life is Good!
Thanks bob, I am going with custom wheels so I think it should not be a problem.
Diesel truck, should I buy it??? 1931 steve Hotrodders' Lounge 4 08-07-2006 07:34 PM
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
S10 rearend help SBC S-10 Transmission - Rearend 4 07-02-2005 11:01 PM
500 in Chevy AD Truck. Aussie seeks help panhead_pete Hotrodders' Lounge 7 10-30-2002 02:53 AM
