S10 rearend noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 03:48 PM
S10 rearend noise
Hi guys i need help with a problem that has me stumped. My 2000 S10 Pickup 4X4 hes been making some BAD noises from the passenger rearend, its more like a ting noise when you get upto 50 MPH and stops at 60 MPH and their is a slight viberation when you stay around 60+ i have done everything else to fixit but nothing does anyone have anything that can help me
THANKS
James21
Heres a pic of my ride
Old 10-17-2008, 10:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What precisely have you replaced , adjusted , repaired to this rear differential to stop the noise?
Old 10-18-2008, 02:21 PM
well i've balanced the tires,checked the breaks and break caliper and lines, ran the axle to 55 MPH with no tires to see if their was some misalignment in the rotor and i did hear a whine from the passenger disc break and thedisc breaks are good. i didn't go further than that.
S10 rearend measurements rearswap Transmission - Rearend 2 04-10-2007 02:29 PM
S10 rearend on AD truck TEXAS'55 Suspension - Brakes - Steering 4 03-30-2007 11:04 AM
Rearend Noise !! Grogetter Transmission - Rearend 1 11-22-2006 09:54 PM
Rearend Noise riesman20 Suspension - Brakes - Steering 8 10-06-2005 05:50 PM
Rearend swap from S10? yesgo Transmission - Rearend 0 02-12-2004 02:07 AM
