S10 right rear brake light turn signal/ hazard light not working - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-08-2012, 01:22 PM
Its not tilt wheel it has a lock
  #17 (permalink)
Old 07-08-2012, 03:21 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Have you tried a new flasher?
  #18 (permalink)
Old 07-08-2012, 03:33 PM
What I did was swap the 4 way flasher with the turn signal flasher. Still the same lol. No changes but I know I will get it fixed
  #19 (permalink)
Old 07-08-2012, 04:34 PM
EOD Guy's Avatar
I still say you've got a bad ground, there should be a green connector on the frame rail, which is a known weak pint on those trucks, one of those wires should be a ground.......... , I'd clean that connector then, try running a temp jumper wire from the neg post on the battery back to the tail light socket and see if the problem presists.
  #20 (permalink)
Old 07-08-2012, 04:56 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
For reference see attached schematics of the turn signal switch and wiring.
vicrod
  #21 (permalink)
Old 07-08-2012, 06:37 PM
Thank you for that wring schematic. It helped out a lot. It looks like the hazard light are completely different than the turn signal brake lights. So if the switch was bad would the hazards still work?
  #22 (permalink)
Old 07-08-2012, 07:28 PM
GOT IT FIXED.. JIGGLED THE IGNITION SWITCH AROUND A LITTLE BIT AND IT CAME ON . What could cause this?
  #23 (permalink)
Old 07-09-2012, 01:09 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Bad connection at the turn switch connector or a flakey wire in the column.
The turn signal harness inside the column may be worn by the ignition switch activating rod.
Green wire coming loose at the turn switch itself.
Turn switch is a strange animal and does a few things.
Also has 3 points of supplied power
Switched Battery power to the brake circuit (via brake switch)
Battery power to supply the hazards
Ignition power to supply the turns
Front and rear turns are separated into different circuits
In a left turn, the left rear brake light circuit actually shuts off and power is supplied by the ignition circuit thru the flasher
Lot of things going on in that little switch
Rear brake light/turn signal problem new wiring. bobwire Electrical 3 12-13-2009 04:57 PM
brake light and turn signal wiring slammed 57 Electrical 4 10-28-2009 06:25 PM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 01:19 PM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
