S10 right rear brake light turn signal/ hazard light not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 05:09 PM
I have an 85 s10 that has a wiring issue. Okay the bulb is good and the turn signal switch seems to be good because it had power from the connection after the switch. Now the left rear works. The right side doesn't. Any Ideas??
Old 07-06-2012, 05:14 PM
Cape Cod Bob's Avatar
Be sure to check for good ground and cintinuity at connections. There is an open between after the switch and ground. You said the bulb is good so the problem is in the wire, conns.
Get in there and start trouble shooting it.
Old 07-06-2012, 05:17 PM
Thank you.Where does the hazard and turn signal wire hook up after they leave they harness where the switch plugs in?
Old 07-07-2012, 04:47 AM
EOD Guy's Avatar
My guess is bad ground at your taillight housing. Take a jumper wire from a good grounding point and touch it to the bulb housing and see if it works.
Old 07-07-2012, 09:20 AM
Well I was thinking that but my regular lights work when I turn headlights on taillight lights up on same bulb. It has to have ground to it for tht to work
Old 07-07-2012, 09:50 AM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
The easiest way to find out is to go to the light bulb socket and see if you have voltage. If you do it is a ground side problem or a bulb. If you dont have voltage and since you know you have voltage after the switch the problem is in the wire. You need to trace the wire and visually inspect it for being broken. If you dont see anything obvious I dont recommend it but the easiest way is to pierce the wire every foot or so until the voltage is no longer present. When you find it just replace that section of wire and check the socket again.
Old 07-07-2012, 10:03 AM
Do you know where the hazard light wire hooks into the turn signal wire. I know that pretty much eliminates the switch being bad but the i need to figure out where those run into eachother
Old 07-08-2012, 04:24 AM
EOD Guy's Avatar
I'm not pos on your truck, but every other chevy I've ever worked on, the tail lights (running lights) are seperate from the turns/brakes and the runnings lights socket could be good and the turn socket might not have a good ground........ hince the temp jumper from the socket to a good ground test
Old 07-08-2012, 04:42 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Have you actually tested the bulb to make sure it's good or just looked at the filiments for breaks?
Old 07-08-2012, 08:17 AM
Yes I have made sure the bulb is good. Its a double filament. Works on the other side when I put it in the socket but doesnt work on right rear socket. The running lights work on the same bulb on the right. Turn signal, Brake light and hazard does not. I dont think it is getting power to the dark green wire but I dont have a multimeter to tell
Old 07-08-2012, 08:25 AM
Very good, I was wondering if you tried the bulb on the other side, I am amazed at how many guys don't do this. I had a "tech" () in the shop the other day tell the office that a car needed a door lock switch because it wasn't locking and unlocking the door. I walked out there, popped the other doors switch and checked it and you guessed it, worked like a charm. insert two rolling eyes smilies.
He had spent a BUNCH of the customers money on this problem and it really ticked me off, sorry to highjack the thread.
Old 07-08-2012, 08:27 AM
Getting back to your problem, those lights as I remember have a short harness that plug into the main harness at the left frame rail, check that plug. I think it has one there, haven't work on one in a while.
Old 07-08-2012, 08:28 AM
Yeah, some people just dont think about it or something Idk. I dont believe the malfunction switch is bad but i could be wrong. Both the front turn signals work. But just the one dark green wire has no power and ground is good because I just replaced it.
Old 07-08-2012, 11:19 AM
yes it does have harness there. Idk how to check to see if is alrite. Looks like there is a 4 way plug in deal back there like you said where a bunch of wires plug into the 4 wire connection
Old 07-08-2012, 11:45 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Check for power at the green wire in the 4-way plug (trailer connection), with someone stepping on the brake pedal.
If no power----
Follow that harness all the up to where it connects to the firewall.
(not sure how yours connects, but my old C-10 has it's harness and connector
at the firewall)
If no power at the front end of the truck, I personally would be willing to bet
that you have a bad turn switch or harness.
For a relatively quick check, with that harness unplugged at the firewall, apply 12 volts to the pin with the green wire and see if the light comes on-----if it does, your wiring to the rear is okay.
If it does not----and assuming that your dash harness has not been molested, it is most likely a bad switch.
Front and rear turn signal circuits are completely separated within the turn switch.
If you lil s-10 has a tilt steering column, the wires could have broken inside the column.
I have had to replace the the turn switch in my 79 C-10 3 times for broken wires inside the column-----constant up and down of the steering wheel had fatigued the wires to their breaking point.
Bryan
Rear brake light/turn signal problem new wiring. bobwire Electrical 3 12-13-2009 04:57 PM
brake light and turn signal wiring slammed 57 Electrical 4 10-28-2009 06:25 PM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 01:19 PM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
