S10 Steering Column Schematics - Help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2007, 07:04 PM
loiselle's Avatar
I have a 1990 Chevy S10 tilt steering column in my rod. It has two plugs on it. One I know goes to the fuse box. The other I do not know what to do with it. I assume it has something to do with wipers, washer, and cruise control, but do not know how to use it. Does anyone have a schematic of this column's wiring or know where I can get one. My local Chevy dealer doesn't and Alldata doesn't either.
Help?
Old 01-13-2007, 01:14 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I am subscribed to www.Alldatadiy.com for a 1995 S10 Blazer. The 1990 is similar.
Alldata can be tricky sometimes but if you go to "Lighting and Horns" then to "Electrical Diagrams" then to "Exterior Lamps" you will see a diagram for the turn signal switch and related wiring including the wire color codes etc.
Then go back to "Vehicle" then to "Starting and Charging" then to "Diagrams" then to "Electrical Diagrams" you will see a diagram for the ignition/start switch.
Same thing for cruise control.
See attached lighting diagram.
vicrod
Old 12-13-2007, 09:12 AM
hey
i want an s10 custom crome steering column where would i look any websites you know of?
Old 12-13-2007, 09:23 AM
loiselle's Avatar
S10 Steering Column
I got my S10 steering column from Ebay. However, I later found several at local junk yards for around $125.
Old 12-13-2007, 05:16 PM
hey
i want a custom one not a stock one a crome one
Old 12-16-2007, 08:26 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Best bet would be a column from Flaming River or ididit.
Old 12-10-2008, 04:14 PM
84 s-10 colum wiring
I have a 84 or 86 s-10 steering colum in my car but need a wiring harness diagram.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Steering Column Wiring loiselle Electrical 3 05-16-2006 11:08 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 02:06 PM
custom steering column Blob Suspension - Brakes - Steering 5 07-08-2005 02:28 PM
wiring diagram for 1987 S10 (steering column rodrigjose Electrical 3 02-04-2005 07:12 PM
