S10 t-5 scarce? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 09:25 AM
need strog32 chevy front doors
Last journal entry: Tbd
S10 t-5 scarce?
I feel like the s10 t-5 with mechanical speedo is getting scarce. I can't find any pre-87 . All i see are the newer t-5's from 94's and newer. ANyways i need one and want to know how much work is needed to configure a newer one with electrcric speedo with an old sbc
Old 02-25-2008, 12:25 PM
Holder350's Avatar
Auto Parts Professional
dont use the s10 t5
its not a WORLD class tranny, you need to find a t5 from behind a V8 or have the s10 t5 worked on to put all the world class parts.
anyhow....I know they make a kit to convert the mechanical drive to electric, but I do not think that there is a kit out there to go backwards.
Old 02-25-2008, 12:50 PM
I thought the pre 1987 s10 t-5 trannys were NWC and thats what hotrodders want because the mechanical speedometer is easy to work with. Your saying that i need the WC tranny which I'll find from a t5 from behind a V8 or have the s10 t5 worked on to put all the world class parts. Maybe i'm wrong.
Are those kits expensive?? And complicated to convert
Old 02-25-2008, 05:08 PM
Holder350's Avatar
I only know of one man who would be willing to do it and hes keeps a WC t5 setting on the shop floor because of the loads of people who want them, He sells it to them on the bases that they trade theirs in on it.
As I understand NONE of the S10 t5s are WC, for the simple reason that they were not needed because of the HP rating.
Old 03-01-2008, 12:02 PM
Last journal entry: fun to drive
You are correct a NWC has the mechanical tach. I believe TCI guages may have a converter you are looking for.
As for the t5 out of an s-10 it would not be concerned with this unless you plan on putting a lot of H.P in your v8
Old 03-01-2008, 01:59 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Absolutely true..In the 4wd world they are swapped out for a t350 with a transfer case from a full size truck as the transfer case and manual trans from and s-10 just is not strong enough fro that app..
Sam
Old 03-02-2008, 09:14 PM
Holder350's Avatar
Sam
Thank you Sam. If you want to put this trans behind a V8 (of any size) AND sleep at night take it to a reputable trans shop and tell them to put world class parts in it.
OR Get a T5 from behind a V8 pickup....but be warned the trans from pickups have a much wider gear set in them.
Old 03-03-2008, 09:01 PM
runn141's Avatar
Sam
the s10 transfer case is strong enough to use with the trans adapter. the fullsize has the driveshaft on the passenger side.
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 03:57 PM
v8 S10 questions mpottspeoria Engine 4 04-17-2009 08:45 AM
S10 truck transfer cases - 4WD to AWD curtis73 Transmission - Rearend 6 04-17-2007 02:22 AM
S10 frame help. matt167 Suspension - Brakes - Steering 15 07-28-2006 07:10 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
