S10 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 09:23 PM
need strog32 chevy front doors
Last journal entry: Tbd
S10 tranny
Forgive me for asking but i'd like to know what year s10 5 speed tranny I should be on the look out for. Which is the most troublefree year. Which year doesn't require electronics and such. I want to bolt it up to my 250ci 6
Old 11-23-2007, 03:23 PM
31 five window
Last journal entry: grill and rear end
They are all pretty much the same except for electronic speedo.I dont know what year this started but pretty sure sender can easily be changed to manual. You will have to change your clutch disc as it has different splines.
Old 11-23-2007, 07:15 PM
Wiki Edits: 31
1985 and earlier had a .83 OD, after that were most all .73 overdrive... the only diffrence...
Old 11-23-2007, 09:22 PM
Which is the best and what should i be picking it up for $$$. Also is there a way to see if you getting junk. For rearends you can inspect the gears but what about these trannys, can you pull the ""cover off"" to inspect.
electronic speedo-sounds troublesome
S10 V-8 tranny problems IbanezPunk129 Transmission - Rearend 18 08-31-2007 08:43 AM
Did Isuzu use same 5 speed tranny as S10? shad88 Transmission - Rearend 2 06-23-2006 05:58 PM
Coupling S10 tranny to SBC Nightfire Transmission - Rearend 7 06-03-2005 10:59 PM
S10.....tranny swap. poncho62 Transmission - Rearend 5 03-26-2005 05:33 PM
tranny help for my s10 speedracer0006 Transmission - Rearend 1 10-03-2003 02:10 PM
