| Register now (free) or login to remove ads | |
Tweet
#1
S10.....tranny swap.
I have an 83 S10 Blazer 4x4, with the 2.8 /auto trans with OD..............I am thinking of
doing a v8 swap with an automatic. I have a turbo350 with short tailshaft laying around. I was told that I can take the tailshaft housing off and put on the transfer case adapter, with only slight modification to the inner shaft. I was told that I could cut about an inch off the shaft and still have enough spline to go into the transfer case. Anybody know any more on this subject? |
| Sponsored Links |
#2
V8 S10 forum some1 in there should have the info u need, IF no one else chimes in....joe
#3
Hoping someone here had done it.................I belong to too many damn forums now.....thanks
#4
Here is what I could come up with quickly.
But that can't be the only solution. I'll look some more. |
#5
the auto trans in the s-10 now should be a small bell 700r4 turbo hydramatic with a 4x4 out put shaft .
To cut a short piece off the 6 inch output shaft of the t-350 tranny , then bolt the t-350 in place will require the spacer / adapter that was developed when 700's were being replaced by the hundreds. The adapter is machined to insert and align the parts. Standard OE style Square cut O-rings are used. The kits came with some pieces of ALL thread and nuts to bolt it all together The 6 inch t-350 turbo hydramatic output shaft is tooo long to cut off and directly bolt up. There would be NO splines as I recall. The adapter was used to keep everyt thing lined up with the shorter t-350 turbo hydramatic |
#6
Thanks Cros.................will probably look for a 700 out of a 4.3....
| Similar Threads for: "S10.....tranny swap." | ||||
| TH-350 - 700R4 tranny swap | 73monte | Transmission - Rearend | 3 | 03-25-2004 02:26 AM |
| tranny swap | bildo95 | Transmission - Rearend | 8 | 10-01-2003 01:01 PM |
| S10 V8 Swap | Thuggishruggish3000 | Engine | 1 | 08-04-2003 12:00 AM |
| Tranny swap | HotRod63 | Transmission - Rearend | 2 | 12-03-2002 03:02 AM |
