s10 trans to fullsize pu swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2003, 05:43 PM
Post s10 trans to fullsize pu swap
will the transmission from a chevy s10 with 4.3 and automatic fit into an 86 full size chevy truck with an auto 700r4 with a 305 v8?
Old 02-23-2003, 05:46 PM
Post
Yup, it'll bolt right in, you might need to change the governor though.
Old 02-23-2003, 06:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
the correct 4.3 S-10 tranny will have a higher stall speed converter, smaller boost valves in the pump and sometimes a smaller 2nd gear servo than a V8 700R4. These parts can be swapped out if you wish.
But it will bolt up just fine.
I did not notice a year of the S-10. If it is newer than 93 it will be an electronic shifted/controlled tranny.
Old 02-24-2003, 05:51 PM
Post
thanks guys your help is greatly appreciated.
