S10 V-8 tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2007, 03:22 PM
Hey guys I put an 84 305 in my 95 S10 which has a 4l60 and it wont shift out of 3rd gear. Is there anything I can do by way of wiring the tranny or something to fix it?
Old 08-29-2007, 05:48 PM
is it the 4l60 or 4l60e?
Shane
Old 08-29-2007, 07:53 PM
I believe its just a 4l60. Whichever one comes stock on a 95 s10 4x4.
Old 08-29-2007, 07:57 PM
4L60E which needs a controller to work
Old 08-29-2007, 10:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a 1995 S-10 would have a 4L60E trans as mentioned....... If you are saying the trans is stuck in 3rd gear with the shifter in "D" that would be correct IF there is no power to the trans.
Default gear is 3rd in this trans IF it is unplugged from the PCM
Old 08-30-2007, 04:51 PM
So yeah it is stuck in 3rd gear cuz its supposed to be there. So how would I make it work with that old of an engine? Oh and by the way when it comes to trannys Im pretty much retarded so explain it to me like Im a 5 year old child.
Old 08-30-2007, 05:05 PM
Would this make it work correctly?
http://store.summitracing.com/partde...5&autoview=sku
Old 08-30-2007, 07:09 PM
no. thats an electric shift kit. you need a tranny controller
you need this http://store.summitracing.com/partde...5&autoview=sku which is $689.95 and this to go along with it http://store.summitracing.com/partde...0&autoview=sku another $199.95 . you can get a rebuilt 700r4 for less then that and it will handle the V8 for years without a problem
Old 08-30-2007, 07:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by IbanezPunk129
Since you have no clue what is going on here;
The 4L60E trans is electronically controlled shifts and pressures by the on board computer of the vehicle.
You must have unhooked the trans or cut the wires on the 1995 S-10 that would feed the trans information.
You can buy an expensive stand alone computer www.compushift.com or buy a regular 4L60 trans that is not computer shifted / controlled . There is a TV cable on a non computer 4L60 and that TV cable MUST be hooked to the carb / EFI with correct geometry and pull on the TV cable for the 4L60 trans to operate correctly.
You will also need to address the lock up clutch of the converter for proper operation. That is easy , there are kits to aid in that setup if you need
Good luck.
Post back when you can.
Old 08-30-2007, 07:41 PM
I have a th350. Would it be a smart idea just to throw that in there. That would make my rpms a bit high tho right?
Old 08-30-2007, 08:10 PM
runn141's Avatar
no higher than what they are now in 3rd gear.
Old 08-30-2007, 08:52 PM
New Member
controller
call summitraceing tell them what you have,they have a self install kit that is fery simple to install i think the kit is around $60.00 good luck
Old 08-30-2007, 08:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A t-350 will not directly bolt into place. Different length case between a t-350 & the the 70 / 4L60 , output shaft from the back of the case is different length.
Move cross members, change drive shaft lengths.
Old 08-30-2007, 10:15 PM
A mechanic told me that if I changed the valve body out with one from a 700r4 or a 4l60 it would take the electric shifting out of the picture. Would that work?
Old 08-30-2007, 10:25 PM
runn141's Avatar
everyone i converted didnt need any changes, i used the same driveshaft and crossmember unless he uses a long tailshaft 350turbo.
Did Isuzu use same 5 speed tranny as S10? shad88 Transmission - Rearend 2 06-23-2006 06:58 PM
F250 Tranny Problems spcaller Transmission - Rearend 2 03-10-2005 08:00 AM
TH350 Shifting Problems SmBlokS10 Transmission - Rearend 4 01-14-2004 08:19 PM
83 Z28 700r4 Tranny Problems Help! ZBAILEY Transmission - Rearend 2 11-09-2003 09:26 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 10:46 AM
