s10 v8 converison - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2010, 07:04 PM
s10 v8 converison
What is the best way to mount the ps pump on a 283?
Old 04-08-2010, 11:25 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
http://www.nostalgicairparts.com/air...racket-264.php
Old 04-08-2010, 07:51 PM
no room
The gear box is in the way of using that setup.......
Old 04-08-2010, 08:39 PM
Wiki Edits: 27
check the bone yard
Gm has used a lot of different brackets over the years. I remember the V 8 Monza had different brackets we used one time. cars, trucks, vans different years and option packages. I remember looking at a lot of brackets until if found one for the 350 in the jeep.
Old 04-08-2010, 08:54 PM
ericnova72's Avatar
More for Less Racer
Try www.alangrovecomponents.com They make steel brackets for circle track and street rod use.
Old 04-08-2010, 09:16 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
ive seen a few made in a shop. but my buddy is a dang good fab man. somethin to think about.its only metal.
Old 04-09-2010, 09:28 AM
Wiki Edits: 27
s 10 v8
I ordered the information from a company, I don't remember which one, when I did the 5.0 into the small ranger pickup. the company also sent me the information about doing the S 10 swap. S 10's are a lot easier than rangers. they sold all the pieces and wiring harness to make it a bolt in swap.
Old 04-10-2010, 04:49 PM
I used a Zoops adjustable bracket on my 86 S10. It mounts low on the engine and cleared the steering box. It mounts off the water pump and to the block. I am running a long water pump and a v-belt setup with this bracket. Been on there a few years now and has worked great. Not sure if it will work for your setup. But it worked on mine.
S10 V8 Conversion pointers........ chevy350_Camd Hotrodding Basics 18 06-12-2012 12:42 PM
S10 v8 swap hearders eric32 Engine 12 01-25-2010 07:22 PM
v8 S10 questions mpottspeoria Engine 4 04-17-2009 08:45 AM
V8 Beetle on S10 blazer chassis??? zbhover Hotrodding Basics 2 10-25-2008 02:09 PM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 12:12 PM
