Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10...V8 Conversion... Distributors??
Old 03-21-2003, 12:38 PM
V8 S-10's Avatar
V8 S-10 V8 S-10 is offline
v8s10.org
Post
The best HEI to use is the 74-early 80s one with the vacuum advance and the 4 prong module.
An HEI only needs the battery wire to work (it goes to the Batt terminal on the dist cap and its only hot when the key is turned on)
Why did you lower the engine bonuts? My oil pan is about 1/4" off of the crossmember and I thought that was low.
