Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 V8 Conversion pointers........
Old 02-10-2009, 09:37 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Use an aftermarket cable operated auto trans floor shifter to shift your th350. ( B&M, Hurst)
You do not need to weight down the truck to get traction.
www.calvertracing.com These "Caltrac" traction bars work great on any leaf spring vehicle including a S-10. Really increase the bite while controling leaf spring deflection, (wheel hop)
http://www.mickeythompsontires.com/
http://www.hoosiertire.com/
www.bfgoodrichtires.com
Get some DOT legal high traction rear tires with a sticky tread compound.
EG: BFG drag radials, Mickey Thompson Sportsman Pro or ET street Tires, or ET Street Radials.
A conventional radial tire does not give enough traction.
