Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 V8 Conversion pointers........
Old 02-10-2009, 09:40 PM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Originally Posted by chevy350_Camd
Hi, I bought a 1988 Chevy S10, and have a 400 horse V8 that I would Like to stuff in it. The S10 weighs 3300, and is a manual. The trannsmission that I want to use is a automatic th 350. My biggest worry is finding a way to shift, because obviously the steering column doesnt have a shifter, but I have a Monte Carlo with a floor shifter. Thats hooked to a th 350 tranny. How would I go about shoving this V8 into the truck and having a shifter ? has any one came across this problem ? if so how did you do it ?.
Questions: How to Convert a Manual Chevy S10 into a Automatic.
Could I run long tubed Holley afterburner headers ?
How Could I weight the back down to get traction ?.
Thanks
1.get rid of the pedal,And put the right trans.
2.no,Not and less you move the motor.
3.set up the back end right,where you don't need any weight.
