S10 V8 Conversion pointers........ - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-12-2012, 11:35 AM
Last journal entry: Volkswagen V8 Squareback project.
Originally Posted by kdickenson456
This will be an unreal truck, once you drive it you will be in for a treat
Same as my VW Squareback with a 350
  #17 (permalink)
Old 06-12-2012, 11:59 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by johnnykool6
Plan on trimming the firewall (not too bad) with that setup. I had to on my '85.....john
You DO NOT have to rim the firewall for the Hedman 69490 headers, but you DO need to trim or dent it in for the 69520 shorty headers.
  #18 (permalink)
Old 06-12-2012, 01:07 PM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
just did one last year with my buddy. the headers was the only really tight spot. you can build them mounts purdy easy. the mounts you can buy work dang good too but you want the engine back as far as you can.we used a bfh alot too. course we moved the engine back 3" more so beat and cut it was.i think your gona like that s10.this one hauls ***.we added 2 long leaf springs to each side and slappers.it could still be better set up. still hops a bit at times.i think if theres any way you can build your headers youd be better off. this 383 puts out over 400 hp and the only headers we found to fit are shortys and they suck big time. way too small dia. too.we're gona have to build some.good luck and yes everthing will fit with the 60$ type mounts but it is a bit tight. this one fit but when we moved it back it was a pita.
  #19 (permalink)
Old 06-12-2012, 01:42 PM
Rickracer's Avatar
If you follow the link I posted above, there are .pdf templates for the (Hooker) TransDapt 4689 motor mount adapters, which work with the regular V8 style motor mounts, and long tubes. (if you can't find it , P.M. me and I'll email them to you) The shorty (69520) header require the use of 2.8 V6 mounts and a crazy looking (adjustable???) mount adapter that isn't very strong. TransDapt also makes adapters to use the stock 4.3 mounts, which I strongly advise against, those mounts don't even hold up to v6 power very well.
My 93 shortbed S10 has a Vortec head hydraulic roller 363ci small block in it, I daily drive it, tow my Vega race car with it, and it goes 8.0s in the 1/8, on street tires. Oh yeah, it can get up to 20 mpg out on the road too, One of these days, after I swap out the stock 3.42 geared 7.5 rear for a 3.73 posi Exploder 8.8, I'm gonna put a 100 shot on it and see if it will get in the 6s.
Header Tube Size - S10 V8 Conversion S10 Racer Engine 1 07-13-2008 11:38 AM
S10 V8 conversion?? PenguinS10monster Hotrodding Basics 9 03-30-2006 11:05 AM
S10...V8 Conversion... Distributors?? TheZaZ Engine 11 03-22-2003 06:03 AM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 06:24 PM
s10 4x4 v8 conversion sweethome18 Hotrodders' Lounge 6 10-14-2002 08:55 PM
