Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - s10 v8 idle overheating problem
Old 07-16-2013, 11:45 AM
bygddy bygddy is offline
Proud LOSER
Originally Posted by eric32 View Post
My current 6 blade flex fan is 17 inches and I looked at summit and I would not know where to start if I need to go to a clutch fan setup.
On mine I had fans from an intrepid I believe, shroud and all, one was switched, and i would leave it running always, the other was on a stat that turned it on a 200, in that configuration the hottest it ran was 210 in stop and go traffic at 40* weather. If I didn't have the switched fan on it ran 210 constantly and would creep higher in traffic. The previous owner had removed the seal at the back of the hood to the cowl and said that made a big difference as well.
