s10 v8 idle overheating problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-16-2013, 02:29 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by eric32 View Post
My current 6 blade flex fan is 17 inches and I looked at summit and I would not know where to start if I need to go to a clutch fan setup.
Forget about the fan and fabricate a shroud. That should be your main concern right now. You could make an effective shroud from scratch by bending up some lightweight aluminum sheeting and pop riveting it together. It doesn't have to be pretty, it just has to guide the air in the proper direction.
  #17 (permalink)
Old 07-16-2013, 03:01 PM
If you use any type of fan clutch on the water pump hub, you must use a factory fan that fits the fan clutch and the fan clutch bolt pattern. That is why fabricators use flex fans and fan spacers.
When I installed a 1970 Pontiac 455 engine in my '55 Chevy, I used a flex fan and spacer, no fan shroud. The 4-tube radiator came from a '68 Oldsmobile and the radiator shop sectioned the radiator tanks and core and neatly fitted it to the '55 Chevy radiator support. The engine ran 180* with a 180* thermostat in Texas summer heat with 4.10 rear gears on the highway at 4500 RPM.
  #18 (permalink)
Old 07-20-2013, 10:04 AM
I found this make your own custom shroud kit at summit and I believe this will be what I need and should work wonders with my flex fan. I don't think I need a clutch fan just yet as tech said I need to get my shroud going first then test and see how this goes. Like I said it pulls a lot of air you can feel itpulling but as you seen the photos its needs a proper shroud like the oem's use. Thanks a lot guys I got a direction and what I need to do. Cheers all.
http://www.summitracing.com/parts/su...8-sh/overview/
  #19 (permalink)
Old 07-21-2013, 01:16 PM
Ok guys talked with my Dad over the weekend and the shroud I posted will not work with what I currently have so what we are going to do is close up the bottom as much as we can and see how it goes. Hopefully it will work but if I need to replace the flex fan with a clutch fan I have several issues. Where I live its hard to find anything less then mid 90's for vehicles at the local junkyards and my belt system is a v belt setup with a clockwise rotation fan and if I got a clutch fan from a local junk yard it will be a counter clockwise rotation fan and a serpentine setup. I just put a brand new water pump on and I don't want to have to change everything out just to run a counter clockwise rotation clutch fan. I want to run a heavy duty one but I don't know the first place to look and how to get the proper depth of a clutch fan. Any suggestions on where to start and what I should look for? I have never looked to buy one before. Hope some one can help me with some info.
  #20 (permalink)
Old 07-21-2013, 04:15 PM
Proud LOSER
If u have an abundance if 90's stuff, why not grab elec fans? Ford focus fans, Stratus or intrpid fans with shroud can be had for next to nothing.
  #21 (permalink)
Old 07-22-2013, 10:04 AM
That is a option but I would like to have the fan instead as I am not a big fan of electric fans. I will see how it goes with a different add on to what I already got then go from there. I can get a standard duty clutch fan from summit but from what I read they don't cool as good as a heavy duty or a severe duty clutch fan. I don't know if a standard duty one would be good enough or not.
  #22 (permalink)
Old 07-22-2013, 10:42 AM
X2 the fan is fine, too much ado about flex fans, they work fine just keep an eye on the rivets securing the blades to the hub, they sometimes fail in groups which risks a blade coming off.
The root problem is the lack of a shroud. The shroud must fit the perimiter of the radiator (at least the core) tightly. Then fair in the shape to just enclose the fan plus some engine movement space around the diameter. Without this type set up the only place the idleing engine's fan pulls air is just in front of the fan. This leaves half or more of the core with little to no air movement hence no heat transfer to the atmosphere. The shroud uses the fan to develop a low pressure area behind the entire core, therefore, there is air pulling through all the available cooling surface instead of half of it.
Clutch fans would make no difference in cooling, though are quieter at cruise where they are not needed so they clutch out and just coast with the air streaming past. Plus, there isn't any forward space for them in an S10/15 conversion. Electric fans suffer many of the same issues with a inability to configurationally cover the needed core area and take up too much space especially when properly mounted using some bracket method that doesn't use fastening the can to the core.
So keep the fan you have and either buy a decent shroud kit; examples:
Aluminum Fan Shroud, 28 W x 18.5 H - Speedway Motors, America's Oldest Speed Shop
A configuration that couldn be home fabricated and is very strong:
Google Image Result for http://www.cadtechindustries.com/Images/products/Offroad%20parts/radiator%20shroud.jpg
Bogie
  #23 (permalink)
Old 07-22-2013, 02:34 PM
I was going to go that route but I can't with the way my motor sits the fan comes above the radiator and even using a smaller 15 inch it still will be slightly above the top. I am going to hopefully enclose the bottom up some and re do the top section and I am also going to try to cut out some of the lower air dam to allow more air as my fan only is pulling air through the top half of the radiator and the bumper air dam on the bottom of the bumper covers the rest of the radiator. Going to try a few things and I will post back of what happens. Getting ready for a paint job too so will have hands full.
  #24 (permalink)
Old 09-23-2013, 01:32 PM
Here is an update guys I just got back from my dad's house and I finally with his help got a real shroud on this thing. I could not use a clutch fan as it hit the radiator and it is forward as far as it can go even to the point we cut into the core support when we stuffed a v8 in it four years ago. Its only low 60's so I can not really test it yet too see if its enough but you can't get any better then this for a shroud setup as its from a s10 and had to just cut some here and there to make it work but man it pulls a lot more air then it used to and I am still having to use a flex fan but if this does not do it then next summer I will get a electric setup for it. Thanks guys.
ID:	83178   Click image for larger version
34 ford coupe overheating at idle rslorenz Hotrodding Basics 13 03-13-2013 02:56 PM
Strange overheating/Idle issue. JoBlo Engine 8 10-22-2009 07:31 PM
51 Buick overheating at idle... tylordurben Engine 22 11-09-2007 02:54 PM
Overheating during idle? jabcab Engine 2 06-13-2004 07:21 PM
Overheating at Idle granprix76 Engine 32 05-20-2004 06:49 PM
