We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-19-2009, 05:54 PM
eric32 eric32 is offline
S10 v8 swap hearders
Hello guys have a question for you guys out there running s10 v8 swap headers shorty style from any brand name for a 350 chevy.
Do you have issues with the number 3 cylinder spark plug hitting the number one cylinder pipe and having to cut it to drop it down to get clearance so you can get your number plug in. I had to do that with mine and now am having issues with the passenger side tubes burning up my number 6 and 4 plub wire boots. I am using high temp wire's and boots but no luck. I am using autolight 26 spark plugs.
I was wondering is there a set of s10 shorty headers out there that will just bolt up the the dang block and be able to get your plugs in with out having to cut the dang tube and have enough clearance for your plug wires? I had to do this to both a set of headman shorty headers and also a set of flowtech headers that I have now.
When I bought the 96 s10 they put a set of headman 69530 shorty headers on it and I had chevy vortec heads with straight plugs and according to summit the previous headers I had of the headman 69530 are for gm aluminum angle plug heads only but they fit with out having to do all that but I did not reuse them. I went with instead a set of flowtech and had to cut the one up etc with everything as stated above. What is the best overall shorty headers I can get for clearance and ease of use and changin out plugs etc. I don't want to have to use shorty plugs and other crap. Also what advantage does the ball socket flange have over the standard style collector?
Thanks
Eric
Old 10-19-2009, 06:11 PM
oldbogie oldbogie is offline
Thanks
Eric
This is about as good as it gets.
http://www.sandersonheaders.com/pro...products_id=143
http://www.sandersonheaders.com/pro...products_id=142
Bogie
Old 10-22-2009, 10:00 PM
9K-sbc 9K-sbc is offline
I am currently running some 1 3/4" primary sanderson shorties (#CS13) on a '96 s-10 SBC with angle plug Brodix heads, the steering shaft goes thru the #3 & #5 tubes, I'm pretty sure they are for straight plug heads since it took some denting of the #1 tube to clear the #3 plug etc. I'm saving up for some 1 7/8" fenderwell headers, but then again, mine is race only. Is this a street ride? are you still running the straight plug vortecs?
Old 10-23-2009, 03:06 PM
Yeah my s10 is a street ride. On both of my s10's I had to cut the number 1 cylinder tube to clear my spark plug. Could not even screw in my spark plug at all. Even a shorter plug would not work. This is with both a set of headman headers and also a set of flowtech. From what I am guessing the world and dart iron eagle heads have there spark plugs in the same spot as stock factory gm heads. I would swap out for a full length headers but they don't allow me to have my oil filter on my block have to use a oil relocator kit and I always hated that. Thanks for the info. It seems no matter what brand I use I will have that problem wich I think is crap. Why don't these guys check for things like this when they design them.
Eric
Old 10-23-2009, 07:33 PM
runn141's Avatar
runn141 runn141 is offline
SB S10
ive always used hedman shortys and never had a problem with any clearance. but i have to use a wrench on 4,5,6,7,8 spark plugs.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "S10 v8 swap hearders"
Another S10 Frame swap question joedcu2 Hotrodding Basics 4 07-27-2009 08:35 PM
V8 S10 Swap RadPreacher Introduce Yourself 2 05-07-2007 07:06 AM
s10 4 banger v8 swap computer 47chevrolet Electrical 12 04-26-2007 08:40 PM
1992 s10 v8 4x4 swap MIKE1521 Engine 1 04-09-2007 12:18 AM
87 s10 v8 conversion too__old_for_this Engine 5 11-23-2002 05:24 PM
