-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   s10 v8 swap mounts? (http://www.hotrodders.com/forum/s10-v8-swap-mounts-199855.html)
MrPhotographer06 06-05-2011 09:53 AM
s10 v8 swap mounts?
does anybody here have the v8 swap mounts for s10/camaro?
I need some for my thirdgen, so i dont have to fight the K-member, to put in those piss agrivating mounts, and i dont want to weld them in..
http://image.sporttruck.com/f/techar...ion+mounts.jpg
like that.
They bolt to the easier to get to, v6 mount holes. If anyone has them, is there anyway someone could get me some dimensions, so i could make my own?
:thumbup:
Thanks,
Scott
techinspector1 06-05-2011 03:54 PM
Reverse engineer them, piece by piece. Bolt the rubber mounts to the motor, bolt a plate to the frame, drop the motor into place and connect the dots with whatever material is required. That's how you make pieces from scratch that fit. Done it a thousand times. :thumbup:
355_S10 06-05-2011 04:25 PM
like that.
:thumbup:
Thanks,
Scott
I got mine from this place https://www.s10v8.com/store/home.php?cat=28
easy, there even adjustable to move the motor forward or backward to clear the HEI to firewall. Bolts right up :thumbup:
MrPhotographer06 07-03-2011 10:44 AM
well, the camaro has the bracket holes there, for the v8, and i already had one bolt out, so im thinking im going to cut the bolts, and use shrink wrap tubing. or fishing line to fish (no pun intended) the bolts back up in the hole and bolt from the top.
Just have to move the brake line.
Sorry for the late reply. Been at the fire academy, so ive been short on computer time.
Now im graduated and edumacated. :thumbup:
Bryan59EC 07-03-2011 10:46 AM
AND----a year older :D
MrPhotographer06 07-03-2011 12:57 PM
sho nuff! happy belated to ya brother.
I was at the beach. :thumbup:
RippinRon 07-03-2011 08:06 PM
It's definitely a lot easier with the control arms out to get at them but it can be done with swivels and extensions. I think the 2.8 mounts would make the engine sit higher than stock. If you do go that route post some pics. I'm about to drop my engine in but if I could gain some adjustability that would be good.
timothale 07-03-2011 08:15 PM
v8 mini truxks
When I did my 5.0 into my 83 ranger I ordered the Info from a company that also did the s 10 kits. I looked at the pictures and made my own mounting brackets, also they had the Ford info I needed,,, maverick V 8 motor mounts, and stock exhaust manifolds. econoline V 8 w PS had a fuel pump that fit, 460 van oil filter casting There was a lot of S 10 info in those pages but all I looked at was the ford info. S 10's are a lot easier than rangers. It would have been easier to have done a 350-350 into the ranger.
MrPhotographer06 07-07-2011 08:12 PM
i'm just going with the v8 mounts.. they;re 7.99 and the holes are different.
http://a1.sphotos.ak.fbcdn.net/hphot..._5823524_n.jpg
http://i9.photobucket.com/albums/a51...riversSide.jpg
see, the front 3 holes are what bolts the V8 in.
If youre not on thirdgen.org, thats a good place to be for tech info.
They've got a good swap read.
http://www.thirdgen.org/techboard/en...swap-read.html
lots of good stuff there. helping me alot.
