S10 will not shift into overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2013, 04:49 PM
MJD MJD is offline
I have a 99 S10 with a 2.2 and a 4L60-E tranny. It has 147k miles on it. I serviced it at 80k and again a few weeks ago hoping it would solve the problem. First thing in the morning it shifts fine thru all the gears. The longer I drive it during my 55 mile commute it gets to where it won't shift into over drive. All the other gears still shift fine. It seems like early in the drive overdrive actually shifts in early and gets better and then around 30miles it the problem starts. Any ideas? I have not had it scanned only hooked up to autozone's code reader and it said trans component slipping. Can't remember the code.
Old 03-08-2013, 07:44 AM
You are at the life expectancy of that transmission. About 95% of the 4L60Es that we see have between 120K & 150K miles on them. We average 10+ 4L60E's a week so we see them enough. We do sometimes see some that go more than 200K, but it is not that common.
The other factor working against you is that you have the 4 cyl. engine. GM put a higher stall converter behind that engine to help get the vehicle moving. The higher stall converter generates more heat than a standard stall as what is used behind the V8's. It is very common for the converters in the 4 cyls. to fail as a result of the extra heat. It is imperative that you have the cooler for the trans flushed when you rebuild or repair the transmission to get all of the old metal out. It is highly recommended that you install a larger external cooler for the transmission going forward.
Old 03-08-2013, 07:54 AM
MJD MJD is offline
Thanks for the info Kawabuggy.
Old 03-08-2013, 10:54 AM
GM also put a higher stall TC behind the 4.3 V6's. In the 95+ S-10 the TC used had a code of DBLF. Which is a higher stall than the V8 TC's. I used the DBLF V6 TC behind my Vortec 350 and get a foot stall of around 2800rpm.
So the I-4 has an even higher stall TC. Interesting.
The reason GM needs a higher stalling TC behind the 2.2 is because it doesnt make the torque that the V6 and V8's do. If you had a V8 TC behind a 2.2 the truck would be a dog as the stall speed would be way to low. The more torque you apply to any TC, the higher the stall speed will be. The opposite is true.
peace
Hog
Grand Prix 98 model gt 3800 sires 2 no shift into overdrive anthony600 Transmission - Rearend 3 02-09-2012 03:21 PM
4L60e will not shift automatically while in drive or overdrive gcnetspeed Transmission - Rearend 1 01-19-2012 06:57 AM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
Transmission Want Shift Into Overdrive butchs18 Transmission - Rearend 4 06-08-2005 05:02 PM
Transmission won't shift into overdrive Scuzzy Transmission - Rearend 3 09-27-2003 08:20 PM
