S10 wiper motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2008, 08:59 PM
S10 wiper motor
I have a 1985 s10 im finishing up. It was altogether with a small block in it, but then i took it out to put mine in. I am trying to hook up the wiper motor. There is one cluster of wires coming out of the fuse block, i think its attached to the harness. the cluster comes together to a plug on the end which goes into the wiper motor. There is also a small red wire coming out of the other end of the wiper motor. Where does this go? I know usually red it positive but could it be ground? Thanks
Old 12-18-2008, 03:21 AM
not really sure there are only two wires that work the motor the others are for the delay speeds.the inside also a has a circuit board. i bypassed mine so its just two speeds fast and slow. get a Hayes s10 manual its has all the wiring diagrams might be a orange wire not red
Old 12-18-2008, 07:42 AM
v8 dan's Avatar
Dan 84 s10 with 5.7 TPI,700r4
wiper wire
I have an 84 s10 and checked my wires this morning and they are orange,white,green and purple no red.
Old 12-20-2008, 08:15 AM
So how do i now which wire to spice with if i want a 12v ignition source for the ignition box and electric choke?
Old 12-20-2008, 09:12 AM
v8 dan's Avatar
wiper motor
From what I remember the purple one is your hot lead check it with a test lite , I believe it comes alive with ign on, I will check mine and get back to you
Wiper Motor Problems!! SouthernRodder Electrical 7 06-29-2010 12:28 PM
Wiring New Port wiper motor to GM column bnewsom Electrical 1 08-25-2007 06:43 PM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
Windshield Wiper Motor - '30 Model A StripeUSA General Rodding Tech 2 11-04-2005 04:10 PM
