S10 wiring mess - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2006, 05:22 PM
S10 wiring mess
anyone have any pointers on how to wire a 350 into a 2000 s10 and use the factory gauges? is it better to use an aftermarket harness or modify the original?
Old 07-04-2006, 05:33 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Depends..What options are there going to be? Computer control? Smog? Bare bones street rod?
All require different approaches..
One thing for sure..If you use the factory gauges, pull the senders from the outgoing engine and install them in the new 350..the New 350 senders may not be Resistance matched to the body gauges..If they won't fit into the 350...fine the stock sender resistance, and order one to fit a 350 in that resistance range..
If not, the gauges may report in error..If at all..
Happy 4 th Of July!
Hotrodders are the
Most independent
group of individuals
today..
So I guess It's our
Day too...
Doc
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
wiring diagram for 1987 S10 (steering column rodrigjose Electrical 3 02-04-2005 06:12 PM
96 s10 wiring diagram need4speed2345 Electrical 0 04-12-2004 10:46 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
s10 wiring krausman Electrical 3 04-08-2003 12:13 PM
