Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - S10 work/hotrod
Thread: S10 work/hotrod
Old 06-20-2013, 05:23 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by Jim likes old school View Post
I have also seen a ton of camel back heads popping up around here.... If I can find some without 2.02 valves maybe they's be a better start than the 081 heads??
Camelbacks will most likely have 64cc chambers that will lower your static compression ratio without a piston change and I don't think the 305 bore will accomodate the 2.02" valves. You're pretty much stuck with what you have to work with in my opinion......until you upgrade to a 4.000" block.
